Ohiobugeye
At 80 MY memory isn't what it used to be. 15 years ago when I got my 59 Bugeye on the road I converted it to a negative ground system . at the same time I installed a Pertonix negative ground ignition system. The instructions say to run the Red wire to the positive coil terminal and the black wire to the negative terminal. what I don't recall is being the electrical system is a negative ground should the coil wires be reversed? With a points system every place I see says the coil wires should be reversed?
The car has sat for 3 years due to my wife's health issues and I had pulled the distributor out at that time.
