TR6 Clutch trouble
GBV76Tr6
Lost all clutch pressure two weeks ago due to a leaky SC. I it shortly after, clutch worked fine, shifted, wheels spun etc. I left the car up on stands to address some brake issues, and as I was getting ready to start this weekend, check the clutch last night to sure all is well. NOPE. SC pressure, but now it’s as if there’s no pressure plate. Clutch armature moves back and forth with no resistance and I can hear the clink of the throw out bearing as it slides side to side. Car shifts through the gear whether running or not, but no power to the wheels so I don’t believe it’s a stuck clutch. Hoping someone has a few ideas before go through the rigor or removing the transmission to inspetc the clutch. Please help.
Try opening the bleeder screw on the slave. If you get a squirt and the release lever on the shaft moves, then it's a hydraulic problem, most likely a plugged flex hose. Make sure the arm and lever are free also.
Tom
Tom
Tom,
There is pressure to the SC. I have zero resistance coming from the clutch arm, so the slave pushrod remains fully extended. If the pin is removed, the clutch arm swings back and forth freely about and inch or so.
Sounds like the release bearing carrier is hung up on the cover sleeve.
This problem has been documented https://www.buckeyetriumphs.org/technical/clutch/StickyClutch/StickyClutch.htm but the fix requires gearbox removal so I'd be pretty certain that it's not a hydraulic issue before I did that. If you have pressure to the slave cylinder with the pedal released, that is not normal. Either the master is not returning or there is a line restriction. If not, I think you are in for it.
Tom
T General Tech Clutch trouble Triumph 12
RickB MGB Trouble bleeding new clutch MC & slave MG 6
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
R Midget Mark III clutch push rod lengths Spridgets 0
mctriumph TR2/3/3A The worst clutch noise ever heard Triumph 4
Ariddick TR2/3/3A Squeaking Clutch when hot Triumph 82
F TR2/3/3A Clutch Slave failure Triumph 5
Lutz Kramer Clutch Disengagement Austin Healey 15
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 22
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
