While I’m working on my brakes, I figure I better address a problem I appear to be having with my clutch.
The point of engagement and disengagement is too close to the floor. I bled the clutch slave cylinder, but feel like I better do it again, this time with a helper.
Does my problem sound more like air in the system, or is it more likely the slave adjustment I have made?
The shop Manuel says to unscrew the push rod so that all slack has been taken up between the rod and the internal cylinder. I have done that, and then I then adjusted by backing off .1 inches, all to spec.
However, this does not seem to resolve my problem. So, I have a question.
When the Manuel says to take up all the slack, do they mean that I should keep turning that push rod not only until all slack is taken up “gently” finger tight, but that I should continue to muscle it as hard as possible, without tools, of course, so that the cylinder is pushed all the way back before I make the .1 inch adjustment?
For some reason, and with my slave cylinder, there is a point when the push rod is fairly tight, but will continue to get tighter and tighter as I muscle it by hand.
Should I do that, forcing it all the way to the end as tight as possible by hand before I make the .1 inch adjustment?
Thanks all.
Thanks all.
