One day when driving the TR3A, after driving 10 miles or so, I went to push in the clutch and it was very hard to push (required 3 or 4 times the normal pressure). On the way home, at times the clutch was normal, other times it took quite a bit of pressure. As far as I can tell, when the engine was hotter after sitting in traffic, stop lights, etc, the clutch was much harder to push in.
I drove it last weekend and there were times that the clutch was "normal" and other times it was just a bit harder to press in. Using the electric fan, I made sure the engine stayed in the "cooler " range (below 190). The clutch slave cylinder is adjusted properly. There are no leaks in the system.
Has anyone else experienced this? Any ideas on a fix?
Sam
Sam
