Hi all -
Looking for some input / guidance before I pull the transmission out of the car.
Car : 1960 BT7
Problem: Grinding noise when clutch pedal is pushed in
Last week while driving the car I noticed I had a slight grinding sound coming out of the clutch area with a slight smell of something burning. I put it up on the jack stands and took a look underneath. I noticed the slave cylinder was leaking some fluid so I thought that might be the issue, not disengaging the clutch when depressed. I changed out the slave cylinder and started it up.
The noise continued and when I depressed the clutch pedal in, the noise grew in both sound and intensity to the point where the engine stalled out. I'm pretty much resigned to the fact I will have to pull the tranny, just curious as to what everyone thinks could be the problem.
One interesting thing....When I mated the transmission back on after an engine / transmission rebuild about 4 years ago, I could never get the clutch to disengage, it would always drag. I modified a pin to be 1/3 inch longer than normal and used that in the slave cylinder with no problems. I could never understand why the original pin didn't work if the slave mount points where on the block/bell cover. Is it possible something was not aligned correctly during the rebuild?
Thanks for reading and for you input.
Jim
Car : 1960 BT7
Jim
