Close to installing the dashboard for a BJ8
Jerry
We should have all the parts together and ready for install this weekend. Anybody done this and wish they had ????? prior to installation? Everything looks pretty good. We have to screw the center console to the two wood dash pieces. Then we will install the gauges, switches, and glove box.
Soon it will look like a car!
Jerry
BJ8 in progress
Just did this. If I had it to do over again, I'd check the fit of the transmission tunnel, with carpet installed, the center console and the center section of the dash. All of these components must fit, and if there is not enough space, adjustments must be made. I mention this because you are probably dealing with new carpet, maybe some Dynamat or such under the carpet, etc., which will change the original amount of space available to install the console and center section of the dash.
Make sure the driver's side part is centered over the steering wheel column. A small thing, but makes the final installation look better.
Charlie
Thanks for the advice. I notice with a trial fit today that the end supports are a little off the holes in the side of the car. I will do some adjustments.
Jerry
Glad you said to do a trial fit. I found the bracket that I thought should hold the center console, was incorrect. I had to make a new one to get the correct level.
It sure is fun to work on basket cases.
Jerry
BJ8 in progress
Hamish Racing General Tech Close Ratio Gears Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
C TR2/3/3A TR3 close by Triumph 2
tinman58 General TR Well that was close! Triumph 12
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
JPSmit MGB A Close Shave MG 3
WillR MGB Rock auto close out MG 0
BN6_2197 Tool to open/close rain plug of gearbox and rear axle Austin Healey 17
C 1959 Hillman Husky in Close-Up Detail Other British Cars 4
C MGC GTS racecar - close up and personal Racing 2
F Late BJ7- any close to mine? 25281 Austin Healey 14
drooartz Spring must be getting close, I'm spending money MG 0
JPSmit And my Birthday isn't even close Other Cars 19
68_sprite so close for a 5speed transmission swap Spridgets 35
64rocksprite rocker arm fitment - how close to 'center'? Spridgets 8
M_Pied_Lourd TR2/3/3A TR3A Rear Close Out Panel Triumph 5
Marvin Gruber Any XK120 folks close to Alabama Jaguar 8
T TR4/4A Close up pics of your TR4a fuel lines Triumph 5
KLUTZ This close.. I'm This Close... MG 9
regularman A close one Spridgets 16
T Getting close. Triumph 6
M Anyone in Md. Close?? MG 1
tinman58 A close call!! Triumph 12
regularman Wow, its close Spridgets 25
T Spitfire My Spit needs a frame. How close is a GT6. Triumph 9
K TR4/4A Will a TR3A trans cover fit a 4A?...close? Triumph 8
jaegzie Close Tranny shifting pattern Spridgets 0
D TR6 Black [or close] TR6 north of Kirkland today Triumph 5
68_sprite close but no cigar.... Spridgets 4
Michael Oritt MGA MGA Close Ratio gearbox saught MG 3
JPSmit So close and... looking for a part Spridgets 1
tinman58 That was close! Triumph 10
tony barnhill Glasiator Cabinets On Close-Out Restoration & Tools 3
Shealey Getting close with the wiring Just one problem Spridgets 4
Scott_Hower Close call MG 16
T A Close Shave Today Triumph 12
Hooper11772 Sooo close!!! Spridgets 39
Hap Waldrop Drew's engine, is getting close Spridgets 3
Stewart That was to close MG 2
Newkie Trunk lid wont close... MG 13
jlaird Boy its getting close Spridgets 11
middleagecrazy Who is close to Knoxville Tennessee Spridgets 26
J Clutch pressure plate very close to gearbox Spridgets 3
roscoe Not Done, but close Austin Healey 24
Baz So close...... MG 5
1976Midget close call Spridgets 12
swift6 Very Close call tonight... Triumph 6
A BJ8 - Scoop and Grill Install ? - Close up Photos Austin Healey 16
NickMorgan A close shave! Triumph 13
J So close yet........ Triumph 10
