have a '71 non-PI TR6 which has sat for about two years with occasional starting and drives around the block. To get serious this year, I pumped out the old fuel, replaced with new; dropped the oil pan and cleaned it out, replaced the oil filter and oil. This car has always started fine; even with old gas and after sitting for months but this time no luck. I pumped the lever attached to the fuel pump and noticed bubbles and some, not much, black gunk in the see-through plastic fuel filter with paper element below. After pumping around twenty times, the bubbles went away, the level rose to the top of the filter and I could feel resistance building as the fuel made it to the carbs. Pulled the choke and it started right up. Put it into reverse to get out of the garage to avoid asphyxiation and it stalled. I noticed the fuel filter was now dry and started pumping again—same thing, bubbles but very slow rise of fuel. I decided to stop exercising my wrist and to seek assistance. So here is my question and sorry for the long build-up but this is my first post. I imagine that there is something wrong in the fuel pump that it is not maintaining pressure and is allowing the fuel to drain back down out of the pump and into the fuel lines leading to the tank. Thoughts welcome. I am the second owner; the first was a woman who commuted in the car for about 15 years in San Francisco.
