Can't believe I broke my rotor
How about Gorilla Glue? I'd mail you one, but it would get there faster from Moss or a local supplier.
Just put on the spare you kept, last time you replaced the rotor
Seriously, you should have a spare on hand. Order two of them.
Probably won't hurt anything to try gluing it together, but I have serious doubts it will work for very long. Lots of electrical stress on that plastic, and the edges of the crack provide a path for the voltage to follow to ground.
Bummer 2 Wrench, guess I better put a spare on my list of parts to order.
Tinkerman
Dennis !!
You know you need at bare minimum:
4 spare rotors
4 spare condensers
4 spare sets of points.
These cars gobble up rotors. I had a rotor fly apart
one hour out of the box.
d
I have a question for you, 2wrench. How did you manage to break it?
Tinster said:
Dennis !!
4 spare rotors
4 spare condensers
d
Dale ain't too far off. I order them by the half dozen. Always carry 2 spares.
Well, I had this friend over to help me (more like we have fun shooting the
bull and teling stories....
Anyway, he touched it a couple times; closed and opened the distributor
cap and the rotor fell to pieces. Go figure.
If it broke when the distributor cap was being closed and opened check the cap carefully for damage aswell maybe an idea to order a spare cap aswell
I get my cap and rotor at World Wide Auto in Madison, WI. And change them once a year, or about 10,000 to 12,000 miles. I don't carry a spare.
https://www.nosimport.com/
Cap is made in Germany and rotor in Italy.
Before installing the rotor I use a small screwdriver and make several lite vertical scratches inside from top to bottom. This makes sure it fits snugly on the shaft. (A tip from Jeff at Advanced)
Cool, Tom. Thanks for sharing. I'll try that. I suppose the thin
scratches leave very small raised areas on each side and that makes for
a slightly snug fit, huh?
mgnewbie I can't believe I broke the head bolt! MG 8
Bob Claffie Would you believe --- Spridgets 14
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
S Can't Believe I'm Doing This Other Cars 20
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
drooartz Just ordered me a new Jeep, there is a logic to it [though none believe me] Other Cars 13
AngliaGT Can't Believe that it's Been Three Years..... MG 3
rkep01 I can't believe that it's finally begun Spridgets 10
Morris I can't believe it! Spridgets 3
roscoe Not going to believe this one. Austin Healey 2
T I can't believe it - daughters B-day gift Spridgets 12
2wrench I can't believe what just happened Triumph 27
regularman I believe a blind man, might be able to see my... Spridgets 14
T would you believe... Triumph 9
V I can't believe my eyes! Triumph 14
Adam58 You'll never believe... MG 4
bugimike can you believe this? Spridgets 6
H Well you are not going to believe this!!!!! Spridgets 11
vping Can't believe I fit my 1972 Midget in.... Spridgets 18
Brosky I can't believe the difference in the speed!! Triumph 19
jaybird WHOA! Another BCF first I do believe! MG 11
KVH General Tech Angle Drive Broke (Repost) Triumph 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
F BJ8 Dipstick Broke Austin Healey 14
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Got_All_4 TR5/TR250 Rope trick on a broke valve spring Triumph 8
R Bugeye rebound strap bolt broke Spridgets 2
jlaird I broke eBay Spridgets 2
S TR2/3/3A exhaust manifold with rusted and broke studs Triumph 5
steveg Poly bushing broke after 1 month use Austin Healey 2
B bj8 bonnet release broke Austin Healey 11
B Help - broke down on road - battery good but no power to starter Austin Healey 17
X don't fix it if it ain't broke Spridgets 1
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
R Broke off d*mn bolt MG 3
6 HELP! something broke in the rear end... Triumph 71
G Driveline broke !! MG 38
Basil MGB Broke down on Rt66 Spotted 10
B WHOOPS! Broke the bezel Triumph 2
Keoke All of CA Not Broke Austin Healey 0
deadair Broke Down Today Triumph 14
tahoe healey Hand break - broke Austin Healey 8
G Broke the stupid heater pipe Spridgets 5
1 Window crank handle broke MG 12
DrEntropy Brakes broke... Other Cars 13
W Broke check strap on door Triumph 4
Dadandson Broke a *^%&$#% Piston Ring Spridgets 2
davester #^*][%$@!broke@#$%^]^%!@brake@#&*$@!!^stud!*@##$!! MG 8
usaflm dang radiator broke Spridgets 5
