TulsaFred
I just finished removing my finicky rear wheel cylinders. I read all the threads and the workshop manual but it was still frustrating.
Here is what was needed to get the cylinder out of the slot in the backing plate:
1. You have to remove the piston from the cylinder first! It says this in he manual but the threads usually dont mention it. I couldnt get the cylinder out without doing this.
2. Remove all 4 bolts from the backing plate to get it free. It wont come off because of the hub, but it gave me the additional little bit of clearance I needed.
i had to do both of the above. Either one alone and there was still not enough clearance.
HTH
Fred
HTH
Fred
