Bug eye front disc brake conversion.
ichthos
Getting ready to make a front disc brake conversion after a year of getting all the parts I need. I got a lot of good advice from an earlier post, but does anyone know if there is a video that shows how to do this? Any help is always appreciated.
Kevin
Do one side at a time so you’ve got something to reference. I combined mine with a major suspension kit upgrade, new wishbones, wheel bearings, sway bar, new calipers I figure brakes one thing not to scrimp on, SS brake lines. There is a video tgat shows rebuilding the front end, if you are upgrading to disc redo suspension and you need to take all of apart to replace spindles. Oh and rebuilt shocks from Peter Caldwell. Toughest part will be getting bushings reamed before it all goes back y to ogethef
Thanks for the feedback and tips. I totally rebuilt my bugeye doing most of what you did. I kept everything stock as possible. I had not driven a bugeye before my restoration and have made just a few minor changes to make it more practical to drive. My wife loves to drive it and just doesn’t feel safe with the shoe brakes.
Kevin, I agree. Bugsy when I got him had totally new brakes including new 7/8” Master installed, new drum brake hardware F and R. I added brake fluid, system was new and dry. Bled brakes, adjusted brakes to the best of my ability and tried driving him for a month. Granted new shoes need to bed in but in 2 month I never felt comfortable in Bugsy’s stopping power. That switch to front discs with 3/4” Master and later rear brakes with the upgraded backing plates and 3/4” large rear wheel cylinders made a tremendous difference in stopping power.
A buddy had discs up front but kept the 7/8” Master and stock rear drum set up. First time I drove his car I was scared to death, what’s wrong with the brakes am I going to stop. brake pressure on pedal extremely hard with no modulation possible. He’s continued to upgrade and not has upgraded MC and gone to later rear backing plates w later rear brake set up. Easy to stop, brakes balanced, nice pedal pressure. It stops!
when you pull brakes from a donor you need to move the entire brake system not just parts and pieces. I did not move over to he dual master as I did not want to butcher the car under hood but I did utilize the same size MC at 3/4” that the later Spridgets were designed with.
I was going through my old post on the disc brake conversion and realized that the I am missing the emergency brake rods from a later Sprite. Anyone know where I can get these?
A donor car someone is trying to get hauled away. You can use old rods but will need to cut, thread cut ends and use a coupler nut.
BillD Bug Eye front drum brake question Spridgets 12
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
T Bug Eye Heater Switch Help Spridgets 2
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
F Bug eye interior Austin Healey 2
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
Joe Schlosser Bug Eye Bonnet Removal Spridgets 1
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
Jer Seen a nice "survivor" Bug Eye on the weekend Spridgets 5
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
T sound for a bug-eye??? Spridgets 2
T Lubricating the steering rack on a Bug-Eye Spridgets 12
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
donbmw For the Bug Eye fans Spridgets 4
donbmw For the Bug Eye fans Austin Healey 1
rkep01 1959 AUSTIN HEALEY "BUG EYE" SPRITE / AUTOCROSSER Spridgets 6
N Bug Eye Hard Top query?? Spridgets 6
Keoke Restired Bug Eye for sale Spridgets 0
B bug eye hard top for sale Spridgets 3
M Bug Eye Door Seals Spridgets 8
jeff1977 Bug eye, id help please Spridgets 21
T Bug-Eye Wheels and Tyres Spridgets 10
T Bug-Eye rebuild & upgrades - advice requested Spridgets 2
J New to forum/new to bug eye/new to vintage racing Spridgets 5
Jer you never know... I just bought a Bug Eye ! Spridgets 21
T Bug-Eye Bonnet Mounting Bolt Lengths? Spridgets 2
M Pocket project completed on Bug Eye Spridgets 5
M New carpet set install on Bug Eye Spridgets 15
M Ignition conversion on 58 Bug Eye back to original Spridgets 2
M New Bug Eye Owner Spridgets 10
B 59 Bug Eye Options Spridgets 9
sim Bug eye sprits How may are left Spridgets 15
C A garage find Bug-eye Spridgets 19
GB1 Interesting Little Bug Eye Spridgets 1
dosedtoaster taking delivery - 61 bug eye Spridgets 29
tony barnhill Weird Little bug eye Spridgets 8
K Austin Healey 1958 Bug-eye colors Austin Healey 1
pbraun Bug i nearing final completion Spridgets 11
pbraun Closing in on finishing the Bug I Spridgets 12
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix...Now with Video! Triumph 43
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix... Triumph 15
Mickey Richaud That's Not a Bug; THIS is a Bug! Other Cars 2
AN5Sprite Some Seasonal Tunebug Pics Spridgets 24
Trevor Jessie The Ugly Bug just got a little uglier Spridgets 20
AN5Sprite Tunebug comes to life Spridgets 10
Hap Waldrop Tunebug' head repaired and on it way back to Steve Spridgets 23
AN5Sprite Tunebug engine diagnosis, thoughts anyone? Spridgets 47
AN5Sprite Tunebug is all alone now. Spridgets 3
