Just finished tearing down the engine in my 59 TR3 and am slowly working through degreasing everything. Since it will likely be months or even years before I can afford to fully reassemble it, I’m wondering about how to treat the block post cleaning. I’m planning to use CLR to remove rust from the innards after degreasing, and then priming the outside surfaces. Should I use some sort of an aerosolized oil (wd40) to coat the inside?
Hi Guest!
