Lynn Kirkpatrick
I have tried bleeding the brakes on my '68 MGBGT. BUT, if I use the usual method where someone pumps and holds the pedal while I open the bleeder, the pedal doesn't go down. It's the same for the fronts or rears. They bleed OK if I use pressure and backfill from the bleeder screws, but it's messy, as it seeps out around the loose bleeder screw. When I first bought it 10+ years ago the warning switch gizzy was frozen. I took it apart got it working again. Is it likely that seized?
I had myself thinking that with 2 separate systems, the old pedal method was impossible. Since only one system is open when bleeding, the other would still hold the pedal. Is there enough movement in the warning switch gizzy so that the pedal will move and each side can be bled individually? I have read in other manuals with similar systems to pump the pedal.
The real questions are how do these systems work and why won't the pedal go down with the old pedal method?
Thanks!!
Thanks!!
