pkmh
Hello all, Not quite sure what my problem is just yet regarding my tranny. Problem so far is minor but symptom nonetheless is, during normal acceleration and after depressing the clutch pedal, I almost always feel as though I am lightly hitting against a gear tooth when I shift from first to second gear and from second to third (never from third to fourth and if I change gears at very low acceleration, problem is even less noticeable). Never a crunch or bang but a "feel" or slipping of the gears when shifting, but ever so slightly. Could it be a clutch or hydraulic problem? I will replace the flexible hose, slave, pin and re-bleed. As for the tranny oil, I do use the Valvoline 20W 50. Before changing the tranny oil however, I had this problem when I purchased the car but never figured out what oil was used prior. And what I know so far about tranny oil, is a product called "Redline" which may possibly eliminate the slippage sensation. Haven't investigated, yet. Until I get to examine the aforementioned possibilities, I also figure it could be the synchros. Anything else I left out? But for the moment and assuming the clutch and hydraulics are okay and there are no complaints about the oil I am using, I so far see there are two different type synchros offered on the market. One made of bronze and the other steel. For a 67 BJ8, can someone shed light on this topic and anything else that could relate to this problem? Figure I gather as much info before adventuring further. Much appreciated. Paul
Hi Guest!
