RAC68
I am a little concerned that the last 2 times I checked my brake/clutch fluid reservoir, I found the level had dropped to almost ½” below the separator in both the brake and clutch sections. This is a little misleading as the original level was well above the brake/clutch separator so the loss of fluid was even grater. The first check was after a Memorial Day parade during which the clutch was used heavily. The second time was after a 3 mile back road drive with moderate to light clutch usage. Since both brake and clutch sections were down, I can not rule out that only one system is at fault and splash-over is the cause of both being low.
Thinking that since both reservoirs appeared lower and since I refilled with DOT 5 Silicone fluid before letting the level fall further, my thought was to let the system showing the lost-fluid tell me which unit is failing. My first action was to check the brakes and, given the volume of lost fluid, no wheel brake seemed to provide any definitive indication. Although I did not pull the calipers, no fluid was apparent on the outer side of the disks and no fluid appeared on any peripheral components.
As for the clutch system, the cap of the clutch slave appeared oily on the outside (could be engine oil) and did show a light film on the inside, however, no volume of lost fluid was present when the rubber cap was pulled. This may not be a good indicator as any fluid passing the rubber cap would have been deposited directly on the road.
So where does this leave me? Since the brake system seems to be functioning properly with no hesitation or excess force required, I intend to first rebuild the clutch slave cylinder as this would be the simplest and least expensive way to narrow down the source of the failure. If the problem continues, I then am concerned that the fluid could be leaking into the air chamber of the brake booster and I am afraid I would have to pull the unit and disassemble it to make a determination.
I would appreciate getting a consensus on my approach and, most important, if anyone has a way of determining if fluid is being collected in the booster while the booster is in-place?
Thanks,
Ray (64BJ8P1)
Thanks,
Ray (64BJ8P1)
