Schroeders
Member
Hello,
I have decided to just put a BJ7 and older exhaust on our BJ8, knowing that the tailpipes will be exiting the wrong side etc, I just like the sound of the earlier systems. I had removed the rear mufflers long ago and fab'd up pipes in their place, but the center muffler is rotted to the core now, and it's time to change it all.
So having said that, my downpipes are in good shape and I'd like to keep them in place if possible. However, they are shown with different part numbers; will a BJ7 center muffler section bolt up to the BJ8 downpipes, or are they longer / shorter? Would leaving them just push the end section out further or not allow to exit far enough out?
The mounting brackets look to be in the same place on the earlier systems as well; should the early system bolt right up with new hangers, or will I need to attached new brackets as well?
Thanks all!
Thanks all!
