Best electric fuel pump for Weber DGV carb
lbcfan
I'm trying to decide between a Carter P4070 (rotary vane) vs a Facet Posi-flow solenoid-type pump for a bugeye.
I have a Weber DGV carburetor which I understand does better with the Carter pump, but the Carter draws 4.5 amps vs 1.6 for the Facet. I can barely keep the headlights lit with the generator now.
Any thoughts on the relative advantages of the two? Both are maximum 4 psi.
Thanks in advance.
something like this?
HXj4Wl8" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Sorry- could not resist :jester:
m
The rollervane runs too high of psi, you will overrun the carb. You have to keep it 2-4psi
Fuel pump
Advance auto
airtex E8016S
$50
Low pressure 2 - 3 lbs
Yep, just makeing the point. We keep getting the same question.
This pump lists for $42 on amazon, I believe it was $49 shipped which is a great deal.
