Austin A70 Hampshire [1950] as a donor car
zblu
Aside from the head which will do as an emergency head, what else would be of use for my early BN1?
Havent seen it yet, but have been told it has had the front stubs removed for another use around the farm some time ago.
Also has been garaged for 18+ yrs so has little rust apparently
Seems according to knowledgeable folk that the entire diff drum to drum is the same as is the crank,g/box,regulator, trafficator assembly,regulator,front drums,coil springs,regulator,maybe steering box,genny,and all those nuts, bolts and other hard to find bits!
