Remember that little trick of inserting "headless" bolts into the rear engine block, where the transmission bolts go? Well, I'm trying to remember--is that done only when removing he transmission to avoid excessive weight on the input shaft while maneuvering, or is it also done when reattaching the transmission to the engine, in this case just as a guide?
Hi Guest!
