twas_brillig
	Each of our squab seats has 4 cross-headed chromed screws, a bit less than 3/4" long, along with a trim washer sticking through them.  The seats are not fixed in place as the screws do not seem long enough to penetrate the steel body.  I've felt around the underside of the body plus used a mirror to try to have a look (not particularly successfully) and can't find any holes for the screws with this somewhat cursory inspection.  I assume I should remove the screws, place the seats, predrill some small diameter holes, and then screw them down.  Am I missing something here?  Thanks, Doug
				 Hi Guest!
Hi Guest!
 but were afraid to ask:
but were afraid to ask:  STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the
STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the  smilie in place of the real @
