BJ7archaeologist
Member
I’m having my BJ7 aligned today at a shop. I need the tow-in specs. I realize that the camber is not adjustable. I don’t know if the castor is either. Thanks!
I believe the original specs were for the bias-ply tires and you'll have different specs if you have radials. I "think" toe-in for radials is "0"?? Someone can chime in if they know for sure.BJ7archaeologist said:I’m having my BJ7 aligned today at a shop. I need the tow-in specs. I realize that the camber is not adjustable. I don’t know if the castor is either. Thanks!
Freudian Slip, no doubt!BJ7archaeologist said:I’m having my BJ7 aligned today at a shop. <span style="font-weight: bold">I need the <span style="font-style: italic">tow-in</span> specs</span>. I realize that the camber is not adjustable. I don’t know if the castor is either. Thanks!
To clarify, the only Healey I own (approaching 34 years now) is a BN6. All the BJ8 pictures I've posted in the past few years are of a couple of MKIIIs that I've worked on (both are BRG, to further confuse things).TodE said:Randy, is 1-1 1/2 neg camber and 1/32 - 1/16 toe in good for all Healey's (100-4 - BJ8) or just BJ's.
Thanks
