Wanted Adjustable steering wheel circlip
James A Martin
I have an adjustable wheel on my TR3B and the wheel had a keeper ring between the wheel ID and the splined shaft. It kept the wheel from pulling off the shaft towards the driver. It looks like 1/8" diameter wire bent into a circle. The ring fit in a machined groove around the OD of the splined shaft about 1/4" from the end of the shaft,
Moss Motors catalog (# 21 CIRCLIP, adjustable wheel TR2-3B (LHD) )N/A.
When I took the clip off it sprang away and I haven't found it yet. Please msg. me if anyone has one. Fabbing one is on my list...Id rather have one I could just snap back on...
Price plus shipping happily paid.
Jim
Jim
I have a drawer filled with all sorts of circlips.
Send me all the appropriate dimensions and I'll send it to you for the cost of postage.
This part is 1/8"dia. round wire, spring steel or stainless and fits into a groove with 11/16" od making the ID of the ring have 11/16" ID
It's not often I get stumped like this.
Are you certain of the numbers you gave me?
I have a 1/8 inch wire coil spring that is close to that 11/16 ID but it seems too stout for the application.
Can you use a snap ring?
Since I'm always away from the computer please call or text me before 4 PM PST @ 650-455-1110.
Thanks,Stephen D'Angelo
1107 Galvez Drive
Pacifica CA 94044
1107 Galvez Drive
Pacifica CA 94044
11/16" is the diameter of the groove the wire retainer fits in after the steering wheel is slipped on the 3/4" splined shaft. Exterior retainer style.
The groove is 1/4" from the end of the shaft and is 1/8 " wide, leaving 1/16" exposed and stopping wheel movement towards the driver.
1/8" steel or stainless wire is the material the clip is made of.
I remember thinking it was a unique retainer when I removed it.
I measured with a digital caliper.
I think a snap ring might work but it would have play in the round groove.
I haven't played with it yet and will probably end up with bent wire or a snap ring to make do.
Any one who has an adjustable wheel with out a nut on the end of the shaft would have a such retainer clip.
Jim
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
AUSMHLY Adjustable steering wheel removal Austin Healey 5
D BT7 adjustable steering column / steering wheel Austin Healey 1
Lin Loosening adjustable steering wheel Austin Healey 3
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
D Adjustable steering wheel stuck Austin Healey 6
K Adjustable steering wheel setup Triumph 2
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
GregW Adjustable steering wheel Austin Healey 13
P Adjustable steering wheel installation Austin Healey 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
C Non-Adjustable steering column questions Austin Healey 14
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
4tecdog Adjustable Steering how? Austin Healey 8
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Crankshaft Adjustable steering column? Triumph 11
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
longbridgehealey adjustable steering Austin Healey 6
tahoe healey Adjustable steering tightening Austin Healey 13
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
G Adjustable steering Triumph 4
H Adjustable Steering Problem Austin Healey 4
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
P Adjustable Steering Triumph 2
