Hello everyone. I have a question about the oil pressure line/setup that is on my 1976 1500. I can't find it showing up in my Haynes manual, my VB catalog or Moss catalog. The guys at Moss had no idea what I was talking about either. So I'm wondering if my setup is unique?
There is a fitting in the side of the engine block, underneath the distributor. It's threaded into the block, and has a 90 degree nipple connected to it. That nipple is clamped into a hose that is 1/8" I.D. hose. Then that hose loops under the steering shaft and connects to a tee fitting on the wheel well. There it splits and from that tee it has an electrical sending unit (not sure what for because there is no idiot light for oil pressure) and feeds the small pipeline that feeds oil to the back of my oil pressure gauge on the dash.
So, here's my problem: recently that hose starting leaking. I tried getting a new one from numerous hydraulic hose makers in my area but no one had hose or clamps that small. So I double hose clamped it at each end after removing the old crimp clamps that were leaking and put it back on. When I did that, one of the compression nuts split! So then, because they were metric fittings that I could not find anywhere I replaced the fitting in the block which was threaded american into the block but metric on the outlet, with a fitting that was american both ends. Then I replaced the metric compression nut that split with an american compression nut. Now it's all "rigged" together and seems to be holding until yesterday when my oil pressure dropped too low and I realized it was leaking again.
What I want is a correct replacement hose but Moss and VB don't show anything. Does anyone have any suggestions? If it wasn't for the "tee" fitting that was metric I could probably figure some way to convert it.
Any ideas please?
Jeff
Any ideas please?
Jeff
