2" spacer blocks for front suspension
Lin
Hi gang. I am full of questions and problems today. I feel a little foolish asking this question, but I always swallow my pride to be able to do the job right. When I assembled my front suspension I put the 2" spacers ( I used wooden blocks) between the shock platform and the shock arms to set the proper height. I am now finally ready to set the car on the floor.
The engine/gearbox is not now in the car (hopefully, next week). Because the front end of the car doesn't have the weight of the engine, when I jack up the coil spring bottom plate I just lift the entire car rather than compressing the spring - so I get no slack enabling me to remove the wood block. Is there a way to do this? Or, do I have to wait until I get the engine/gearbox in?
I should mention that I have Putzke's Bilstein tube shocks installed at this point.
Lin
1960 BT7 in restoration
1959 Bugeye
Re: 2" spacer blocks for front suspension
Lin,
You should be able to remove the blocks after you put the car back on the ground. You might need to 'bounce the suspension' a bit to get the clearance i.e. use your hands and body weight to activate the suspension .. if the block doesn't just fall out you may need to tie a string around the block and have someone pull when you bounce above the shock!
At any rate, I wouldn't put the motor/gearbox in while it is on jack stands. Too precarious!
Cheers,
John
Hi Lin, I wouldn't worry about removing the blocks now. The blocks will fall out when you get the engine and gear box back in the car and set it back on it's wheels.--Fwiw--Keoke
Thanks, fellows. I'm getting close and just don't want to mess up now. I actually have the car off the jack stands now John. Wheels and tires on and they are sitting on those dished metal rolling dollies so that I can move the car around easily in the garage.
Lin
1959 Bugeye
keoke, im curious as always, mind splainin whats goin on with them 2" spacer blocks ive gotten really good at doing front ends and rather enjoy doing so, but never employed this method what up wit dat? never to old ta lurn ya sumtin, come on ill buy ya a "rum and mango" /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Good mornin’ Anthony,
That block is to set the suspension in the middle of its travel before you tighten down all the bolts. You want the rubber bushings to flex equally on both compression and extension of the control arms. If you tighten everything while the suspension is hanging, the bushings will twist too much going over things like speed bumps. Same thing applies to the leaf springs.
Hi Anthony, Greg gave you a good splain. I only want to expand on the concept a bit: These blocks set the loosely assembled front suspension component at or near their normal ride height. Consequently, when you tighten the lower A arm trunnion bushes, upper arm bushes and the lower A arm bushes it relieves the strain on the rubber parts as Greg mentioned and allows the lower A arm trunnion bushes to go all the way home aligned. It is noted that the spring is not installed when this final assembly of the suspension is done.--Fwiw--Keoke
C HD6 Carburetor Spacer Blocks Austin Healey 4
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
G TR6 Carb Spacer Triumph 4
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
T TR4/4A Rear Bump Stop Spacer Triumph 1
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
M TR4/4A TR4 door glass spacer wires. Triumph 1
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
T TR2/3/3A Question on spacer in Moss thin belt/damper conversion kit 837-508 Triumph 3
PatGalvin TR2/3/3A Heater Spacer Threads are a mystery Triumph 4
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
S TR6 Anyone have a spare alternator fan spacer? Triumph 6
bertl Front Hub Spacer Kit Triumph 1
DNK Strom Carb spacer Triumph 25
richberman pinion bearing spacer Austin Healey 11
britndablood To install or not to install Front hub spacer Austin Healey 8
TR3driver Differential collapsible spacer Triumph 6
AUSMHLY Wheel spacer for a BJ8 needed, help please Austin Healey 33
T TR2/3/3A Spacer on TR3 spring? Triumph 7
E TR2/3/3A tr3 fuel pump spacer Triumph 6
T Gasket behind servo aluminum spacer? Triumph 5
I TR6 TR6 traling arm spacer question Triumph 3
A MGB motor mount spacer[s]? MGB MG 6
swift6 bearing spacer needed... Help! British Motor Corp 6
jhorton3 Seat Runner Spacer Spridgets 4
RickB What to use for spacer on rear springs? Spridgets 6
Hap Waldrop Carb spacer question British Motor Corp 5
Nunyas Wheel Spacer Source? Racing 8
tomshobby fuel pump spacer? Triumph 8
A axle leak and bearing spacer measurement Austin Healey 8
Monark192 Interesting Radiator Spacer MG 11
jlaird Question - stearing rack spacer Spridgets 6
Scott_Hower MGB MGB plastic fan "spacer" - which side of the fan? MG 16
AUSMHLY Heat shield spacer Austin Healey 17
F For Sale Rover V8 blocks for sale Other British Classifieds 1
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
5 TR2/3/3A Wooden blocks Triumph 3
5 Hardtop wood blocks Austin Healey 3
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
C TR2/3/3A 1957 TR3 Garage/ barn find> On blocks 48 years Triumph 42
B Sanding blocks Restoration & Tools 2
deadair TR2/3/3A For those who's TR3s are up on blocks Triumph 14
Brosky Sealing blocks are available again Triumph 5
BOBBYR Sleeved blocks Austin Healey 11
Mg_Bizzle Lowering blocks and front sus [newbie fitting q's] MG 20
Darwin Up on blocks Triumph 2
G She's up on blocks....again Triumph 3
