The acquisition of a Moss aluminum oil pan for my BN7 Healey 3000 several years back suggests I finally offer the original to a new owner. You may note the silvery streak in the outer surface near the plug. There is a crease in the metal at that point, and I had flowed lead solder into it, anticipating repainting the pan. That never happened. The metal was not penetrated at that spot and this pan does not leak. If desired, I can send a photo showing that area on the inside of the plan. The other photo shows the typical abuse found on these pans, none of it acquired during my ownership. If desired, I can include what I think may be all of the original bolts and the odd-shaped washers. The aluminum pans require longer bolts, rendering the originals unusable for that purpose. I offer the pan, plus bolts if desired, for $90 plus shipping costs
. It weighs about 8 lbs.
