TR2/3/3A Fascia Capping
LionelJrudd
In response to Windsor's request, pictures of the fascia capping (the aluminium capping above the dash).
L
LionelJrudd
Windsor asked for a photo of the fascia capping I made. Below are some photos of the process I followed. The 1.5mm aluminium used was excess to requirements from some fascia on the house we built.
Started by bending some water pipe to the profile of the edge of the dash top.
Added pieces to maintain the correct angle of the pipe relative to the top of the cowl. Roughed out a pattern on the aluminium sheet to approximate the capping.
Clamped down and bending sheet. Metal was mostly eased up around the profile for the main length and then worked with the hammer around the ends to bring it into shape
Once the inside was started to be folded down, a fair bit of hammer work was need to stretch the metal on the inside curve.
Trimmed the ends where it meets the doors. When fitted to the dash it was obvious that I had not allowed enough metal at the ends to reach where the tenax studs hold it onto the cowl.
Added some sheet metal to both the inner and outer sides. My first attempt at tig welding aluminium sheet. Not too glamerous but it dressed up OK.
A little more dolly work and trimming the edges and it fits well. Especially happy since it will eventually be covered in vinyl.
Frank Canale
Hi Lionel, Impressive for a first attempt at tig welding aluminum. Cleaning the aluminum of its oxide coating is key as well as cleaning you tig wire. Great job, looks great. Thank you for the pictures, love seeing your work. Frank
Frank Canale
Hi Lionel , here are pictures of the bottom of my original capping. maybe this will help. The slots are 35mm X 18mm and slanted at roughly 40 degrees. Frank
L
LionelJrudd
Had no idea that's how they were drilled. I assumed there were just round holes for each screw for the hand rail. This forum is great for those situations such as this where you do not have a sample to work from. Thanks for the info Frank.
Frank Canale
Hi Lionel , I did not know what the slots were for but I took it out to the car and found the spire nuts under the edge of the scuttle where the capping fits. It appears that the spire nuts are for the grab bar that attaches to the scuttle for right or left hand drive cars. There seems to be two types of capping depending on commission numbers. This link may help.
L
LionelJrudd
Thanks for the link Frank. I had not noticed it before. Good also because it gives several more photos of both inside and outside of the capping. Looks to me like I got it right. Still have to locate the slots and cut them in. Not a straight forward piece to fabricate because it curves in so many ways.
L TR2/3/3A Fascia capping ends. Triumph 5
D Fascia Restoration Austin Healey 14
Jim_Stevens TR2/3/3A Bakelite ashtray fascia 3D print Triumph 6
S TR4/4A Fascia support and shift rod boot Triumph 0
JimTR4 TR4/4A Does a 4 wood dash fascia fit a 4A? Triumph 2
Brooklands TR2/3/3A TR2 - 3 Fascia on eBay Triumph 12
T Post-War Other Herald dash recovered!! Now Fascia won't fit!! Triumph 1
B TR4/4A Windshield Capping Strip Triumph 5
S TR2/3/3A door capping with buttons Triumph 8
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
M TR4/4A Windscreen capping Triumph 0
G TR4/4A Inside Windscreen Capping Triumph 6
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
K TR2/3/3A Tonneau capping mounting questions.... Triumph 2
K TR2/3/3A Gluing vinyl to cockpit capping? Triumph 5
K TR2/3/3A Rear tonneau capping plates and bridge pieces for mounting the Hardtop? Triumph 3
Rut TR4/4A Door capping Triumph 7
M TR4/4A Windshield capping assistance required. Triumph 1
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Tinkerman TR2/3/3A Installation - Dash & Dash Capping Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
M TR4/4A Supplier for TR4 windscreen capping?? Triumph 1
A TR2/3/3A Cockpit capping Triumph 7
Tinkerman TR2/3/3A Cockpit capping Triumph 11
M TR4/4A TR4A - need windshield capping strip Triumph 2
S TR2/3/3A tr3 leather cockpit capping dog leg Triumph 4
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
B Door Capping on a TR3 Restoration & Tools 0
Tinkerman TR2/3/3A TR3A Dash Capping Triumph 25
S TR2/3/3A Tr3 dash rail capping Triumph 4
JohnnyMead TR2/3/3A Trimming the Dog-Leg Capping on a TR3 Triumph 9
ekamm TR2/3/3A tr3a elbow capping Triumph 9
rlandrum More Elbow Capping Trouble Triumph 7
CraigLandrum TR2/3/3A TR3A Fiberglass cockpit capping woes Triumph 3
CraigLandrum Wood under from dash capping? Triumph 11
jjbunn Windscreen Capping - Sealer? Triumph 4
Moseso Leather Capping: How-To ? Triumph 5
TR4nut Windscreen capping piece for Surrey Top? Triumph 3
angelfj1 TR4/4A TR-4 Aluminum Windscreen Capping Triumph 5
PeterK TR2/3/3A How do I remove TR3 door capping Triumph 6
J removing the "capping" over the doors, etc Triumph 2
